I finally got my new pc put together and decided to stress test it. PC is i7-8086k Asus Maximus x hero, gskill trident z 3200
When running the "optimized defaults" in bios, I can stress w/ prime95 and it runs just fine, 4.3ghz all core, temps below 70, etc. But if I enable XMP in bios, I go back to stress with p95 and HWinfo shows "yes" in all of the columns for core power limit exceeded, and the cpu will downclock under 4ghz on all cores. Temps are not the problem, they are under 70.
MCE is not the issue either, tried auto, enabled, and disabled. Same issue each time.
I don't know what to do now, All I want is my ram to run at 3200mhz not trying to OC cpu at all.
Any help would be great guys!
