I have an Abit IT7 that I'm using for an HTPC system that I'm currently putting together.
Thing is, when I try using the optical out to my surround receiver, nothing works.
I have it connected properly and I checked the bios to see if something needs to be "turned on" for it to work and I've found nothing.
Any ideas aside from throwing an audigy or a separate sound card? I'd rather use the optical than that crappy 1/8 jack on the line out.
