LanceDiamond
- Oct 11, 2005
IP35 Pro, Q6600 @ 3.2Ghz (8 x 400 - memory not overclocked) @ 1.325v, 1.27v VTT, 1.33v MCH, 68%/68% GTLCPUREF
What is strange about this is that the system passed over 24 hours of Prime95 at these settings. I noticed I was getting an event in the system event log about power management not being enabled on the processor due to a "firmware problem" and I was curious if that meant EIST/C1E were disabled in BIOS so I enabled them. Result was BSOD loading Windows. I bumped the voltage to 1.355v, same result - bumped to 1.455v (I'd used that voltage during testing and it always worked but produced 10c hotter temps) and booted fine. FWIW, the system event about the processor was related to EIST. I dropped back to 1.325v and BSOD again, disabled EIST/C1E and all is well again.
I searched around and didn't find much about EIST causing bluescreen but I guess it makes sense if I'm at the edge of what my CPU can do at a given voltage - and I am at the edge at 1.325v. At 1.305v I get about 40min Prime95 before a bluescreen vs the 24+ hours at 1.325v.
Thoughts?
Thoughts?
