Enabling/Disabling SLI
norky
If i get the dfi board and want to switch between single monitor and dual monitor and I've got two vid cards, do I have to switch the jumpers every time?
I guess I'm just not sure how sli works if you want to have dual (or more) monitor support.
thanks!
No. You can enable and disable SLI in the driver control panel.
The jumpers just effect the lanes on the PCI-E bus. I.e. 8x 8x vs 16x 1x
thanks very much. so then really there's not much of a reason to have to mess with them?
There is a reason (at least once). Once you get them in 8x 8x mode you are good to go. (mine actually came that way on my most recent DFI, but it was form RMA, so I dunno)
I have never tried two cards with 16x 1x, because there is no point. However, I have had difficulties when in 8x 8x mode and only one card in.
