Enabling Albatron FX5900PV 3rd fan?
Èpel
Hey guys, any ideas about how to enable the thrid fan on the Albatron 5900 NU. It only enables if one of the other fans breaks. Someone posted on another forum that the FX5950UV enables the 3rd fan if temps rise above 56 degrees C. This would be awesome on the 5900 NU. Does anyone know if the bios will work from the 5950UV and if so, where can I find it? Also any ideas about how to enable the fan through software or drivers Thanks for any input.
