Hello all,
I just got my Emu 1212M installed, and I thought I'd share my experiences with it so far.
What is it? The Emu 1212M, made my Emu, a subsidiary of Creative, is a professional-level card designed for recording and mixing music.
Why buy it? It sports some very impressive DACs, along with piles of inputs and outputs. This means I can hook it up to about anything, and the quality should be great!
Description:
The 1212M consists of 2 separate cards: One with the actual DSP and digital in/out [coax in/out, optical in/out, a firewire connector, and an RJ45 connection for hooking up an external breakout box full of more in/outs] , and a daughter card with analog in/out [ Balanced line in, balanced line out, and midi in/out] .
The two cards are hooked together by what looks pretty much like a short little floppy cable. Right now, I'm just using the balanced audio out.
After picking up the necessary converters to run this card to an unbalanced amp - http://www.radioshack.com/product.a..._name=CTLG_007_002_001_001&product_id=274-884 x 2 - I plugged this straight into my headphone amp, a Gilmore V2 [ http://www.headamp.com/v2.shtml ] , which in turn drives Sennheiser HD650's.
Software:
Being a professional card, the drivers for this card are fairly complex. Though I don't have any web hosting to post some images, I'll just say it took a couple minutes to figure out how to even get sound out of it =] One other thing to note is that this card will only output one sample rate at a time. If you create a session at 192Khz, you'll only get sound for anything sampled at 192Khz. If you have any games that output sound at lower sample rates, you're basically screwed - the lowest this thing supports is 44.1Khz.
Complex drivers and hassle aside, is this thing worth it?
I'd have to say yes! I used to have a Game Theater XP, while certainly not cutting edge these days, certainly wasn't a bad card either. The Emu 1212M completely destroys it for sound quality. My Hd650's have never sounded this good. I listen to alot of industrial and death metal, and it really brings out the detail in the sound.
Is this card for you?
Well, it costs 200$, it's a pain to get working, evidently won't cooperate AT ALL with any Audigy cards [so you can't run dual soundcards for gaming purposes] , and the drivers have a really steep learning curve, and no printed manual. On the other hand, you get pretty much the best sound quality of any card costing less than half a grand, and it rivals many good standalone CD players, or so I'm told.
If you want more info on this card, you'll find piles over at www.head-fi.org , in the 'computers as a source' forum, and at Emu's website:
http://www.emu.com/products/product.asp?maincategory=754&category=754&product=2209
Description:
Software:
