I use EMIII to monitor my boxes.
For one of my boxes, the magenta Frames Completed bar has been stuck at 2 of 100 for days now. Yet when I check that box's log, it appears to be progressing normally. The green current frame progress bar in EMIII looks fine, and the time per frame matches the log file. Also EMIII shows that box's work unit to be a 600 pointer but I don't believe it is correct (the time per frame is way too short for a 600 pointer).
One more thing. I noticed that box had an early end unit after 2 frames a couple days ago. So it aborted and got a new work unit. It has completed a couple WU since then. The EMIII problem must be related.
I deleted the box from EMIII and readded it, but there was no change. Any ideas on how to get EMIII to properly monitor the box?
