Emergency!!! Big problems with my Windows Home Server!!! Please Help!!!
ave
I was having some problems with my Server and decided to do a Re-Installation of WHS. I selected to do a re-installation and setup was at the point of "Formatting the Volume". It has been stuck their for 3 hours. I then decided to try the setup again, but now it has the 1 option for a New Install only. I have 1 drive for WHS and 8 2tb Drives for my shares. I immediately pulled the 8 share drives out just in case. If I select a new install will it rebuild those drives? I looked at a couple of them and it seems the folders are their but the files are spread accross 8 drives. I don't know what to do, but don't want to lose my Important files. Please help with any guidance. Your help is appreciated.
I just took the main drive out and see 2 partitions. 1 20gb and 1 130gb. The 20gb is blank but the 130gb still is in tact with the data. I read somewhere that I should delete partition 1 and then the reinstall option should come back. I tried that but it still says New Installation. I took my Data drives out and then put them back, but stupid me didn't mark which one goes where. Will that matter for the reinstall to show up. If so how can I fix this.
The problem is most of my files are split between different drives. What is the best way to copy them to a new drive? If I install the WHS Software and then put back my data drives, what will happend?
Thanks
I don't beleive so. How can I check that. Will it matter which order the data drives are in? Do I have to format the 20gb Partition for the reinstall or just delete the partition?
Thanks
I can't advise you about WHS recovery; sorry! Hope someone can, i do recommend not to do anything 'stupid' until you got clear advise on how to proceed.
An easy way to look at SMART data in windows is to install CrystalDiskInfo and look at the raw data. If you do not understand the output post a link to a screen capture of that.
That one looks good K: . However there is a Caution on the C: and N: drive. Can you post that one.
C and N are for another computer. I just put it in this computer so I can manage the drive.
The software is saying that there is a problem (that may indicate it is dieing) with the C: drive.
c and n are not from the server. It has nothing to do with it. only drive K goes in the Home Server.
Bad news for you. I had the same thing happen. Basically I just backed up my OS drive ( not the Sys partition but what little actual data was stored there) and then yanked all the data drives. Did a reinstall, and proceeded to add the data back to WHS across my LAN ( funny, about 3 hours into it I was on newegg upgrading to gig ethernet, lol, ;) ) You may be able to search online, but imho that was the safest way to do it for me even though it took a long time to transfer 4.5 Tb across lan.
Also, make sure youre copying the actual data, it should be under /drive name/share . Not near my WHS so I cant remember 100% but theres 2 versions of the file, one thats the actual file, and one thats like a bookmark for WHS.
Yea, i'm manually backing up the files as we speak. It's a long process. The files are in the d:\de\shares directory? What a pain.
