EMC SAN Setup: What am I missing?
3one5
I picked this up a few months ago and am now getting around setting it up. I believe the model is CX3-20 but I'll have to double check that. I need help with the connections. The drive chassis has copper fiber channel connections while the storage processors have fiber connections. How does the drive chassis connect to the storage processor?
The SFP port in the middle next to the orange bit? The other two SFPs presumably go to your FC switches (or HBA if you don't have one).
Thanks guys. I went digging through my cables and found what i needed.
This is the cable you need SFP on one end and HSSDC2 on the other, if you need 1 or 2 i have some extras, PM me.
I found one, I'm pretty sure the others are around. I may hit you up if that isn't the case. Thanks!
