emachines T3406
Hman
Anyone wheather I can install a SATA drive in this ?
Also is it compaitable with DDR2 ? I know it has a DDR PC3200 but some websites say it supports Supports Dual Channel DDR ( like the memory configurator at oempcworld)
it says :
PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR.
it says :
i dont think that board has any sata connectors but all you have to do is look. dual channel and DDR2 are two different things. based on the questions you are asking i recommend that you dont work on the computer yourself. :eek:
