neoreturns
- Mar 20, 2002
I have a few questions before I buy it. Please try and help me out
1. With only PC2700 is it using some sort of divider? I assume the A64 is running at 200 mhz?
2. Is it easy to upgrade to the newest Catalyst drivers and do they work fine with the widescreen? Or do you need to download a modified .inf/.cfg file that some user created?
3. How is the TV-out quality?
4. Is 1280x800 bearable at that resolution? WXGA is the lowest end of the widescreen screens, and I'm wondering if they look good (both my BB and CC, dont have them on display)
5. Can you have 2 batteries in it at once?
6. Is the hardrive 5400 rpm? How much cache?
7. Will emachines still provide support if we go to Windows 64 bit when it comes out?
Thanks I think thats it for now.
