I do not get a green LED light on the systemboard when the orginal PSU is connected. However, I tried another PSU and get a green light on the system board, but that is it, no sounds, no beeps, no fan spin. No, I get no lights on the HDD LED, PWR SWITCH LED or POWER LED. the green light I do get with the new PSU just tells me the PSU I am using is good, right? At least this is what I thought.
My next step is to remove the system board completely from the chassis, unseat all cards, remove all RAM, remove all IDE cables and only have the power supply connected to the system board as well as the CPU/Heatsink installed on the board and see if it powers on. If it does not power on after that and makes no noise, no beeps and no fan spin, is it safe to say the mobo is dead?
I know her PSU is bad, but I think it also shorted something out or may have fried the mobo. Thoughts?? Yes, I know what pieces of crap eMachines are and I should tell the person I'm trying to help that you get what you pay for and never by another eMachine again, ect.
Can I use a volt meter to test anything on it? I used a volt meter to test the CMOS battery and it is 3V, so that seems to be ok. Not a bad or weak CMOS battery. Just for grins, I pulled the CMOS config jumper off for a minute and placed at opposite pin locations, then put it back to it's orginal jumper location. This should have reset the BIOS config, right?
I'm looking for some sound advice here. Thank you in advance!!!
