emachine problems
cieje
So I'm having a problem with a friend of mine's computer; really, it's driving me nuts.
it's some junky emachine. He said a few months ago the cdrw stopped reading any discs - so when he signed up for cable modem service they were unable to install the usb drivers to use it via usb - and there's no nic installed. The drive is seen in xp home - just... when you double click the drive with a disc in it you get a blank directory listing - no errors or anything. Really, the system is just overly slow and not working as it should. He had spyware/viruses etc definatelly. It's a 1ghz with 512mb ram and 20gb HD (like 15gb free) onboard video etc.
First thing I wanted to see... if the cd drive would boot an xp (or any bootable cd) and... well it didn't - tried changing ide cables - channels etc etc. So I put in a dvd drive I had (known working) and it still didn't. So I manually disabled the harddrive from booting and ONLY the dvd drive to boot - and that was fine to boot. But when I tried this with the original cdrw drive still no go.
So under the asumption that the drive was bad, and using my known good dvd drive I proceeded to boot from a winxp home disc (came withe computer) to format and install xp. Everything starts fine, formats fine etc, but eventually I start getting errors during the install that file "whatever" couldn't copy or wasn't found etc - I tried this 3 times with the same results, but different files.
Thinking this was a memory problem maybe, I booted up with a memtest86 bootable cd and after 10min there were no problems found (and actually the 2x256mb DIMMS in the computer were some I had put in a few months ago that were known-good)
So now I'm kind of stumped. Computer will not boot from cd unless the HD is disabled as a bootable item - OS will not install - but mem and system in general seem fine. What should I be expected to be the next step? try a different HD? or am I looking at a more serious MB/PWS or other problem... Looking at the board, there's no bad capacitors or anything; the fan on the cpu is kinda junked up, but the heatsink is pretty cool to the touch despite poor airflow from the fan.
Could be a PSU problem or motherboard. Check for bad capacitors that physically look bulged on the board, then try swapping out the psu unit. While you've got the PC open, clean it out and check if fans are running and temps are ok.
That would be the only other real problems other than a bad HD as HaMMerHeD suggested.
Try the hard disk first. It is a lot easier to swap out than a PSU or motherboard.
I would attest to the psu as being the problem. I'm having similar problems. The PSU was reading way off specs, which did some damage to my optical drives. No memory errors, memory and cpu benchmarking software ran fine, ect. If you can't get sisoft or equivalent loaded, or no PC health bios setting, then get a multimeter and test the power supply.
Also, I swapped out my cd-rom drive with a known good cd-rw with the bad power supply. Now I've got two bad drives... so be careful:D
