Hey guys, just moved my last system over from UD to F@H full time, only problem is that I can't seem to get EMIII to work properly on the machine. When I go to add the command path for F@H and edit all the settings it works fine, as soon as I save it and exit however is where the problem starts. As soon as EM is closed it seems to lose all its settings and once it is run again, asks for all the setup info again. Any ideas as to what's going on? I'm using the latest version (3.5.2) and running Vista if that helps any
Cheers
Cheers
