- Aug 26, 2006
I want to make sure I got this down.
First off, I was unable to find a real clear description for how my electric company charges me their rate per KWH. This is the best I could come up with. I use Dayton Power and Light in here in Central Ohio. I found a PDF file on Google, mentioning that they charge $0.06 per KWH up to 1,500 KHW mo. The rate gradually steps down from there.
But if my math is correct, here is what I came up with. Anyone see anything wrong with this?
I used my Kill-A-Watt meter to determine how many watts under full load my PS3 used to fold. It logged in at 200w.
So I assumed that it would take 5 hours to consume 1KWH. 24 hours in a day, so 4.08 KWHs consumed in a 24 hour period if the PS3 were on all day.
4.08KWH x 30 days/month = 122.4KWH, again assuming the PS3 ran 24/7. Add those KWH to their said rate at 0.06KHW = $7.34 month to run the PS3 24/7.
Does this sound right, I know that YMMV but does this sound reasonable to some of you folding veterans out there? Also, I would hope someone would chime in that is running some serious hardware at home, and let me know what kind of difference you see in your power bill each month.
I just don't want to get a $500 electric bill.. so I am trying to get some ideas for long term solution to fold. Even if that means to take my folder cpu over to the in-laws and let it soak up their electricity to offset my time in fixing their computer every week
Lastly, I am not 100% certain that the rates I found for Dayton Power and Light are even correct, so if someone wants to chime in about that to confirm/deny that lives in the Ohio valley area -- and if this Kill-A-Watt thing is even accurate.
IDK
TIA
TIA
