Mr Milquetoast
- Apr 15, 2005
Ive been having problems with my PC crashing and I believe the problem is a result of a Sitecom KV-011 USB KVM. This sounds unlikely so Ive written a background of what has lead me to this conclusion. However, its a bit long so if you can probably skip to where Ive put a line of dashes if youre not interested in the background.
A little under 2 months ago I bought the Sitecom KVM. On the same day my brother came to visit and returned my graphics card which hed borrowed along with Doom 3. While he was here we were looking at some graphical demos and videos and while watching them one of the graphical demos crashed and Media Player crashed while playing one of the videos.
Over the coming days applications continued to experience errors and I started asking my brother what hed done to my graphics card. The errors became more frequent until eventually the system started restarting unexpectedly. This became a common occurrence, and started happening about once or sometimes twice a day.
At this point I decided find the source of the problem by trying the components of the unstable in my other PC in my working PC. At the time I thought the issue may be with the graphics card so I first tried a card from the other PC but the crashing issues remained. Furthermore the graphics card from the unstable PC did not cause any problems in the other PC, which ruled out any problems with that. I also tried switching the memory and power supply but neither of these was the problem. Next I switched the hard disks and did a clean Windows installation but the PC remained unstable. Finally I tried updating the BIOS to the latest version but this didnt help.
This seemed to indicate that the problem was with the motherboard or CPU but since one system was an Athlon 64 and the other a Sempron I couldnt switch the processor to test this. I resigned myself to buying a new processor but decided to put up with the crashing until the dual core Athlon 64s were released expecting it to lower the price of the single core chips.
Recently however the unthinkable happened and my second PC stopped working. It would not get passed the POST screen (which was a bit of a mess) and I couldnt enter the setup screen. Even after clearing the CMOS the PC would not start or enter the setup screen. I plugged in a PS/2 keyboard in case it was a USB issue but it would still not enter the setup screen or get passed POST.
I swapped all the components over with the unstable PC just to try and get it to start up but even with different RAM, graphics card, PSU and hard disk it continued to do the exact same thing and would not start. I again assumed it was either the motherboard or processor but having never experienced such problems in the past could not believe I was having problems with both PCs. I should point out that no component in either PC is overclocked or operating in any way outside its intended use.
The only thing left was the Sitecom KVM which was plugged into the USB port each time I tried to start the PC since I never imagined it could cause such an issue. However after unplugging it and I turned on the PC and it booted up normally without any issues. At this point things quickly started to fit together and I realised the problems started the exact day I bought the KVM. If simply having it plugged in was sufficient to stop the PC starting then Im sure it would be enough to cause the crashing on the other PC. Its also the one thing I never thought to disconnect because you dont think to disconnect your mouse and keyboard if your PC is crashing. The second has PC remained unstable since I stopped using the Sitecom KVM but at this time Im assuming that the KVM has permanently damaged the motherboard.
The only noticeable issues Id had with the Sitecom KVM was, frequently, when I press the button to change between PCs the mouse and keyboard would not work when it switched to the other PC. Sometimes I could simply unplug and reconnect the mouse from the KVM and it would work. Other times this would not work and if I switched back to the first PC the mouse and keyboard would not work on that either. Furthermore plugging the KVM into a different USB port would not help and I would eventually have the restart everything. At the time I just thought that this was an inconvenience but it may be indicative of a much greater flaw in the KVM.
Since the problems with the second PC started the day I bought the Sitecom KVM and the other PC developed an issue where it would not even start up with the KVM connected it seems very likely that all the problems are a result of the KVM. However, I dont want to start accusing anyone until I have proof so my question is how can I test if the Sitecom KVM is the cause of this?
One thing Ive thought about is testing the voltage and amperage on the USB output from the KVM and seeing if its within the USB specification. Unfortunately I dont really know how to do this or what range the voltage or amperage should be in. The other thing I considered was returning the motherboard to Abit in the hopes they could tell me what the cause of the problem is but Id rather not do that just yet as Id still have to confirm whether the CPU was working.
Id be extremely grateful if anyone with electrical knowledge could tell me how I could go about testing if the Sitecom could have caused permanent damage to the PC.
Thanks a lot for any advice you can offer.
