I want to buy an electric toothbrush. I hesitate between :
Oral-B ProfessionalCare 7850 DLX and Philips Sonicare Elite 7500.
Both are pretty much in the same price range (best model from both company)
wherever it should be doesn't make a difference get the Oral-B only thing i hate about those things though is that it gets dirty really easy and smells after a while and the heads are expensive. Otherwise its great, cleans really well, u still have to use floss though. <---these are my teeth
Go for the Sonicare. I've had one for a couple of years and they are great. The new ones are nice because they are lighter and more comfortable to hold on to.
My mom is a dental hygenist, and every office she has worked in, the dentists always
recommend the Sonicare. Not just for a kickback (even through I'm sure there is one) but because it works, and it works well....
"Such control can get downright anal. The more lux Japanese toilets come equipped with a "washlet" seat with James Bond-like gadgetry built-in: not just a bidet, but a bidet which can be adjusted Fore and Aft). The relative force of this cleansing spray can also be adjusted with the handy electronic display mounted beside the seat (high-end models come with wireless remotes - not to be confused with the one for the TV, thanks to helpful pictograms), and of course the temperature of the water can also be modulated to personal preference."
