Electric disc mod
UnlnvlslblE
Is it possible to put one of these in your case?
http://www.spencersonline.com/index...oductID/97bdfacf-6df6-407a-bdb6-33ace13bd54c/
Its going to be put right behind the metal the motherboard is bolted to. I'll cut a hole in the case and mount it, I'm just wondering if its safe to do. You can touch it and not get electrocuted. Would it cause any interference? I remember seeing a case that had something similar to this, I just don't know if this is going to be safe. Ths biggest thing I'm worried about it the electricety arcing and blowing my computer up. Any ideas or anyone have experience with these things?? Thanks!
It has been done before, but on the side opposite to the mobo. I'm not sure if it would affect the mobo when it's so close.
the only thing I would be worried about is not grounding it. Put some rubber grommets where the screws go in and you should be fine
