It's beta patch , but if you are having problems you can try this(but remember to backup your save games)
]Beta patch
]Beta patch
Won't get or Oblivian, or can't run? Never the less the Result is the same.LostStorm said:I wont get oblivion until my next pc upgrade
robble said:it says you may have to reinstall the game after you load the patch. Anybody feel like being test pig?
