EK Water Blocks
Carlosinfl
Loves the juice
I just picked up this EK water block for my 8800GTS however it appears I can place the 1/2" nozzles pointing north or south depending on my config or perhaps if I chain them via SLI.
I only have one GPU and I would think the tubing would flow better if the nozzles pointed north from the back side of the block, GPU card so my question is how do I stop the 2 nozzle holes on the front of the card from leaking? Am I missing something?
Thanks - I just wanted to be sure that I was not missing something I had to purchase extra.
