Has anyone else had problem installing a motherboard with the ek supreme hf backplate? when installing it as per the instructions with the standoffs, rubber mat + backplate it protrudes higher than the motherboard
standoffs for my case making it impossible to install the mobo into the case without bending it.
Is it ok to install without the backplate if i use a lighter pressure? otherwise im going to have to make a cutout in my mobo tray. There must be other people who have experienced this problem as i thought mb standoffs are all a standard size.
Cheers
Cheers
