Ek sbay o-ring
Nimisys
Is there a reason you can not measure for what size o-ring you need, then go aquire it from a place such as McMaster?
termite
I am going to assume you mean the faceplate oring. Realistically it is probably a common sized oring. Getting the exact size though can be difficult as they will take the odd hour glass shape.
Have you tried to contact EKs customer service? They are pretty good about providing info about EOL products. They may be able to give you the size of the oring, even if they no longer carry spare parts on thier website
I made some inquiries about the first gen Supremacy water blocks and they were quick to answer my questions, in my case the parts were still available on thier website.
