EK Fluid Gaming A240R
Mccaula718
EK just released an kit for vega and it supports Ryzen for $240(link below). My current vega 56 has the following settings in wattman:
Frequency %: 3
Voltage control: 1100 for pstate 6 and 7
Memory:900mhz
Fan speed: max
Power limit: +50
This results in my gpu core clock boosting and consistently reading 1550+ MHz. So my true question is, Will spending $240 drastically improve my overclocks or will it just give me something like a 50 MHz boost? I've never done watercooling so I'm interested in doing it just to do it, but $240 is a bit much if there is no significant performance boost.
https://www.ekfluidgaming.com/ek-fluid-gaming-a240r
yeah you might only get a bit more out of it but your Temps will go way down and you might get your cpu a bit higher too.
This is what I was thinking would be the answer. Thank you and pendragon1 for the responses, I only use my computer for gaming and I wear headphones so I do not believe I'll purchase the kit.
