EK 780i Waterblocks?
KrylonArt
I have heard that EK is supposed to be releasing EVGA 780i waterblocks within the next couple of weeks or so... but does anyone know if they have released concept sketches yet? Would like to see how the NB and SB blocks or going to work since it is my understanding that the blocks for the mosfets from the EVGA 680i are compatibible with the 780i?:confused:
680i blocks are compatible with 780i... I know I have a 680i and am on the upgrade queue.
As far as I know, only the 680i mosfets are compatible. EK Waterblocks has to create new blocks for the NB and SB. I did find a German company who is making waterblocks for the 780i, if you can understand I envy you (I was just using the site as a method for determining how tubing and such might look). Meisterkuhler
I know for a fact I saw somewhere that said the NB/SB for the 680i is compat with the 780i. I'm hunting it down will provide upon finding.
I got this from a pretty reliable source.....
There is nothing available that will fit ATM. NV completely changed the mounting hole pattern (made it much wider for
one) and offset the chip dies from the center of the hole pattern. You also now have to take care on
the PR200 chip as well with the same WB. You will also need a replacement Vcore mosfet heatsink when
going to water on the 780i's Spp NB as well.
I knew I would have to make a mosfet HS for the 780i from the gitgo but like others I had just
planned to reuse the SPP NB WB from my 680i on the 780i. That went right out the window
when I pulled the stock cooler setup off to take measurement for the mosfet HS.
The thread is HERE
