Justintoxicated
- Apr 10, 2002
This seems odd.
290x ek backplate contact by Glamisduner, on Flickr
Ok another question, when I put on my thermal pads I use some thermal grease on the memory and VRMs then applied the pad. However when I attached the black I forgot to add any compound to the other side of the pad.
Should I bother re-doing it? If so can I simply just add compound or do I need to cut up more fujiploy? Stuff isn't exactly cheap...
For the backplate I just re-used the stock thermal pads and only added grease to the side that touches the card as well. I carefully removed the sticker that was on top of those capacitors or resistors or whatever they are, it was really sketchy. I didn't bother removing the entire sticker cause I was afraid of breaking one off with my finger nail. It was stuck on there good. Card is Sapphire brand.
Card is currently mining at 40c VRMS are at 37 and 33c
