EK 150 Reservoir Whirlpool Effect!
amoeba1126
I just got this reservoir and it makes a whirlpool. While it looks cool, it makes bleeding a pain in the butt. Is there anything I can do to fix this?
Stick this in it. Alternatively a credit card also is said to work well.
Make sure it is new or you will have some mutated thing in your tubes!
Either
1) get the new revision by returning your old one,
2) DON'T use the bottom port to feed your pump
3) insert a credit card, cut to fit the center similar to how the new revision looks
or 4) attach a barb to the port up top and attach a foot of tubing to it. Fill the entire reservoir and half of the tubing.
I tested the "slower is bad" idea the other day.
Swifty Apogee on an e4300 @ 3.0 F@H 24/7
MCR320 with 6 Yateloons
EK medium res (which does whirlpool quite readily)
MCP655
all 1/2"
No CPU temp difference between lowest and highest setting on the pump. If there was, it was less than 1C over an hour. I now run at lowest setting because it's quieter.
As have I... Absolutely no difference!
a pump in a fully bled loop shouldnt be all that loud. i cant even hear my DDC2 w/ petra's top anymore, and its plugged in directly to the PSU in my system.
when i first filled my loop, and was bleeding it, i noticed the pump was VERY loud and annoying, but it went away when the bubbles went away.
i noticed with the swiftech mcres a whirlpool type thing is created from the design of the res, and during the bleeding process i could really see it. it was damn cool looking! but now my coolant just flutters about at the top level in my mcres, and thats all the fun i have anymore :(
I only have 1 90degree turn and its on the inlet to the micro res (which ididnt think was too horrible) and about 5 feet of tubing with a ekwave and a stealth block... is it bad if there never was a whirlpool effect?? lol
Don't know if this is true for you or not. I used to live across from a small community airport in Fullerton, CA. After I had lived there for a few months friends would come over and ask me how the hell I could stand the airplane noise. After a while all irritating sounds are tuned out by the mind. Doesn't mean that the sound is less of a problem. So sometimes it is a good idea to get a second opinion from people who don't frequent our computers to often. :)
Just FYI, I turned down my 655 to the lowest setting...with no difference in temps. But YMMV.
I'm not surprised in the least. Are you speaking of CPU temps or water temps? When I did the same thing with my pump I got slightly higher water temps, but the CPU and GPU temps remained the same. Several others have reported the same over the years.
