Does anyone have any experience using an Eizo monitor with the "Smart Insight" feature?
http://www.eizo.com/global/products/foris/fs2333/index.html
A Quote from the above page:
"Master the Game with Smart Insight
You cant defeat what you cant see. With that in mind, EIZO developed Smart Insight technology to vastly improve visibility in dark areas of the screen. With Smart Insight, you can see the vital details that would otherwise be hidden so you can surprise your opponent before he surprises you. Conventional gaming monitors apply gamma correction across the screen to improve visibility which results in blurring and reduced contrast in the dark areas, The FS2333s Smart Insight uses a technique called tone mapping which preserves the image details without reducing contrast. The difference is so significant that its almost like an unfair advantage.
Smart Insight comes with a total of five user-adjustable RTS and FPS settings."
I'd like to know how if any of you that have used this monitor enjoy the feature. What is your experience with it? Pros and Cons? Messing with the gamma is nothing new to FPS gamers, but having a monitor that essentially does that, while not utterly destroying image quality might be something I'd be interested in.
Thanks
Thanks
