Eizo FX2431
I've been waiting and watching the LCD's out there, and waiting for the perfect monitor to suit my needs. I'm still gaming on my 20" CRT, no real complaints - but wanted to eventually get a 1080 or 1900 x 1200 widescreen to also be able to use my xbox on and also watch some movies. I definitely didn't want to settle on a TN panel with horrible viewing angles. I was thinkin about gettin the HP2475, but the big price tag and so-so results of input lag testing made me hesitate. Afterall, I am a gamer, first and foremost. :D
Today I saw this:
http://www.eizo.com/products/foris/fx2431/index.asp#
This looks to be a pretty promising new model from Eizo - what do you guys think? I think that with all the media connection options, the promise of low input lag, and suitability to play 1080p movies makes this one a winner. I only hope it will be availble in the states and for a fair price. I am willing to pay a premium price for a premium monitor, but it also has to be within reason. Otherwise I can get me an "ok" monitor and spend the rest on a big screen hdtv lol.
Yeah, this monitor looks hella awesome. Looks similar to Samsung's T240HD in that its a monitor with a ton of HDTV features, but the Thru Mode looks like it'll eliminate all the massive lag issues the T240HD had. The ability to display 24fps content natively is a killer feature.
Eizo doesn't sell monitors in this country (as far as I know). Though I THINK they mentioned something about starting that at some point, but that was a while ago.
Price-wise, assuming this is an IPS panel monitor, this looks like it might be in the upper $750s to possibly even $1,000 range.
If those are your concerns, then why would you consider an EIZO monitor? The HP costs around $500-$600 and has one frame of lag, while the EIZO will probably cost at least $1600 (if not more) and has two frames of lag. Not only that, the HP has an IPS panel while the EIZO is S-PVA. I see no reason to get the EIZO monitor.
Thanks for setting me straight on the price, I didn't initially have any idea how much it was going to cost. I guess it was just wishful thinking :D
The HP is still #1 on my list, but I think it's actually more like 2 frames of lag (between 30 - 35 ms) average, isn't it? According to the reviews from digitalversus and Prad.
