Hmm are you serious? don't rush with buying the Eizos let other users explain you more about the 2490.
Don't want to look like im saying 2490 is better then the Eizo FX2431 cause i have one.
Generaly the best IPS monitors are better then any VA/PVA.
http://hardforum.com/showthread.php?t=1396129&highlight=NEC+2490+full
Taken from the review.
Conclusion
Over the past two years the NEC 2490WUXi has gained a tremendous reputation of the best available monitor.
This reputation has become so solid and fortified with so obviuos reasons that potential reviewers risk losing their own reputation saying opposite.
I don't want to be among those reviewers.
Just to save you some time![]()
So basically you're saying the Wuxi2 is *worse* then the Wuxi?
Also, can anyone explain why this wide color gamut thing is a bad thing for "most" users?![]()
Thanks for all your input, it's been very helpful.You pretty much talked me into a NEC WUXi now, but I can't seem to find them anywhere online.
WUXi2s all over the place..
I read tons of review about this two monitors.
no need to argue, Foris is really better than Nec LCD2490Wuxi for all round use
and overall I prefer 10 times Foris.
Can't understand how you can compare this two monitors.
Obviously all monitors have Pro and Cons, but Eizo is better for wide gamut, really darker black at the same luminance, better contrast (a must have for video/games/everyday use),
connection tipe, scaling, input lag.
It's like comparing a good wolkswagen with a Ferrari![]()
Isn't it obvious?
The EIzo Foris FX2431, is no match for the best IPS monitor made ever. In fact, its inferior even to some lower end IPS panels. If you can't see the issues with S-PVA or PVA panels in my post then ill suggest you to chek your eyes, no offence intendend. All the PVA or S-PVA screens suffers from black crush and colors shifting! period.
Sincerely when I work on the monitor I sit in front of it and I don't rotate my head like the camera on your video, so no sense to me.
In addition, good PVA have no black crush effect, at least not much more disturbing than the IPS glow.
Sincerely for all rounding I prefer PVA, it's taste.
Мan..come on, just look at the pictures! there is a difference even when u seet in front of the monitor (as some of the photos are taken) all S-PVA/PVA panels has it! this is very very well known fact! And yes, the NEC 2490 has no IPS glow (A - TW polarizer) so the comparasion you make and saying that Foris FX2431 is 10x better screen is totally non logical or correct, actually the 2490 should take that spot. Still i won't go any further then this because its pointless. Sure i can help you "see" or understand some points, but i can't make you see what you dont like to.
So basically you're saying the Wuxi2 is *worse* then the Wuxi?![]()
Viewing angles: Eizo FX2431 features a S-PVA panel and is similar to other S-PVA based monitors.
Cons: Viewing angles, Bulky design and cabinet, Response time
The original 2490 is something of a special classic. No longer available.
It took me 5 different monitors before I found one that was great.
Here is my review of the 2490 after I got it two years ago:
http://hardforum.com/showthread.php?t=1338622
Still love it today.
I would not trade mine for any LCD available today. I wouldn't even consider it.
IPS is the best technology for displaying a stable image, but the 2490 include another polarizer layer that eliminated the off angle glow that you can see on IPS (and other screens BTW). With this extra polarizer, you need a CRT to get better viewing angles. None of the newer monitors have it.
The Foris FX2431 has typical PVA image shifting. Unacceptable for me, but probably OK for most people.
From the FX2431 review:
I've been using my EV2333W that I just received a few hours ago, and so far I have to say it is exactly what I aimed to purchase. Uniformity and grey-scale are superb, with grey 2-2-2 and white 254-254-254 being differentiated. No discovered pixel errors, no audible noise, no tint, and minimal flashlighting.
Contrast is superb. One thing I am disappointed about is the fact that my unit came with the Tristand instead of the better Flexstand. The usual VA viewing angle rules apply, although off-axis viewing angles are quite good. A distance of 80cm from the display largely mitigates gamma shift on critical images like the mountain stripe image. Trailing is evident on certain transitions, and it may disqualify this monitor from being used to play games competitively online.
So far I look forward to spending five years with this EV2333W.
So, no one owning one ended up reporting in?
For comparison I tested the Nec 23" IPS monitor for about a week as a secondary monitor, and I simply had to return it. .
