Gilthanis
[H]ard|DCer of the Year - 2014
- Jan 29, 2006
https://einsteinathome.org/content/gdpr-new-website-features-and-statistics-export-option
GDPR: New Website features and statistics export option
Submitted on 28 Nov 2018 17:11:05 UTC
We plan to upgrade the Einstein@Home Web site this coming week in order to deploy new features that make our project more GDPR compliant. To that end users will see some new options that I will summarize here.
In order to make the transition easier, there will be a two week period after the Web site is updated but before the statistics export option goes into effect. This grace period will end on December 17th. Users should still go to the privacy preferences page, and enable statistics exports in preparation of the new policy.
PS - Some other BOINC projects may also require users to consent to statistics exports soon. This means you must enable a similar statistics export option on their respective Web sites.
Update: 2018-11-29 - The changes to the Web site have been rolled-out. The statistics export option will go in effect December 17th.
- New users may only create an account by registering through the Web site. After your account is created, you may connect to Einstein@Home using a client. We recommend to always install the latest BOINC Manager to ensure compatibility with the current and upcoming changes.
- Existing users will be asked to consent to our privacy policy and forum guidelines upon their next website login.
- There is a new privacy option: Do you consent to exporting your data to BOINC statistics aggregation Web sites? This is set to 'No' (disabled) by default. You may enable the feature in Account -> Preferences -> Privacy.
- Sites that aggregate project stats, such as BOINCstats, may not function for you if you do not enable this option.
