Efficient PSUs that don't start
Yes, I think the site is down.
Submitted by Mike Chin on Thu, 2006-08-24 18:16. Silent Mike's Blog
The following discussion has been added as a section to the Power Supply Fundamentals & Recommendations article. It addresses the issue of modern, high efficiency power supplies that sometimes don't work with some modern motherboards.
Higher efficiency PSUs generally tend to need higher minimum power on the 12V line in order to simply run. Typically, we're talking about 1A or greater. Older, less efficient PSUs have much lower minumum current needs, under 0.5A and often ZERO.
In some recent motherboards, there are various time delays implemented in order to ensure that the PSU (and motherboard) is not subject to a huge current surge when everything turns on all at once. Many Asus boards have been identified as doing this, al though you won't get Asus to talk about it — I tried — they will say it's proprietary information they don't want to share with competitors. They are not the only board makers doing this.
The practice began during the peak of the Prescott era when startup surge became quite serious, but before the 80% efficient power supplies became common. Board makers extended the practice to AMD boards as well.
So this means, for example, that there could be anywhere between tens and hundreds of millseconds between different portions of the board and components being powered up. Just how much delay there is and how much power the CPU/VGA draw affects whether one of these high efficiency PSUs will actually start. Sometimes, adding HDDs will help, sometimes not — they may not pull current soon enough after the power button is pressed to change the current demand the PSU "senses". If the current sensor detects too low a load, the power supply usually does not start.
I don't have concrete information about the time delays involved. However, the Asus boards that would not start with some high efficiency Seasonic PSUs also would not start with some high efficiency PSUs from Antec, Fortron-Source, and Enhance.
A sure-fire way to tell whether too-low 12V start current is the problem is to hook up a known working, older, generic 300W PSU to the afflicted system. If max power was the problem, it would have a hard time starting, or not start at all. But invariably, with these too-low 12V start current situations, such PSUs (even several years old ones that long precede 24-pin ATX outputs, etc.) will start the system fine.
The reality is that most of the better brands like Seasonic and the others mentioned above are going for high efficiency because it is one of the big differentiators between PSUs today, and also very high power output. There are few PSUs that put less than 80% of the total power rating available on the 12V rail. For a 400W PSU, this typically means 320W is available on the 12V lines. You simply don't get a surge that big at startup with most computers, enthusiast or not, so even older PSUs should start fine on most systems
The upside of all this is that most PSU makers are aware of the issues here, and they are implementing solutions. The simplest one is to add just enough internal resistance on the 12V rail to ensure that there is enough current draw to start the PSU even with no 12V draw from the outside. This naturally drops the hard-earned efficiency down a notch, but it is in fact, what some PSU makers have done.
I know that Seasonic has quietly implemented an active circuit that automatically inserts enough of a load so that the 12V line always sees the minimum load, at least, but then this extra resistance is removed when the load gets higher, so that turn-on is never a problem, and high efficiency is maintained at normal and high power operation.
Which Seasonic models? I believe all the current sleeved output cable S12s, the S12-80+ models and the soon to come M12s.
Additionally some very high performance mobos (DFI LanParty is an example) seem to require +5VSB@3A &
most PSU's do not provide more than +5VSB@2A or +5VSB@2.5A. :eek:
I may be having the same problem with the new 520W Corsair HX. It will not start my modern AMD system while my older lesser Power Supplies will. It does work with an old system (pre 12V MB).
By the way, I didn't get a chance to reply to your PM yesterday but I ordered your motherboard from Newegg so it should be here tomorrow. I'll be running a check to make sure it works with the PSU I send you in replacement if that's what we end up doing.
We'll get this working one way or another.
Try holding down the power button for 5 seconds or more. ;)
The Corsair HX620 has 3A on the +5VSB, not sure about the 520W, but probably the same. :cool:
With IDF past us, a topic brought up during the conference was Intel coming up with better voltage regulators I think it was, which would in turn make the PSUs more efficient.
"Being a silicon products company does not mean to limit the business to processors and core logic products. Intel presented voltage regulators that are expected to enable power supplies at an efficiency of 90%. Today, most power supplies work in the area of 70-80%, with only few models exceeding 80% efficiency. The remaining 20-30% are energy that is converted into heat and thus is wasted." - TGdaily.com
Could the 12V rail problem still exist with these new voltage regulators?
Also what will the market do to price vs. efficiency with this new technology being introduced?
What do you all think?
http://www.tomshardware.com/2006/09...e3.html#power_supplies_to_reach_90_efficiency - Link for article on TGdaily about this(scroll to the bottem not much info)
It's funny, because my Enhance 500 watt 80plus power supply would not fire up with my power supply tester........even with a few hard drives and CD-ROM attached. Actually it would fire up for about 2 seconds and then die. I hooked it up to a rig I was working on for a friend which had a 7800GT and OC'd Opteron 146 and it fired right up. It's running without a hitch in my current rig, which is a 7900GTO and a 3800X2.
I had initially bought an OCZ Gamestream 600w (also 80 plus if memory serves), and it would fire up, but my motherboard would not post (this was on a Biostar T-Force 6100 939, I'm currently on a AM2 version of the same board). My 939 board would work with any power supply but the Gamestream, but the Gamestream worked fine in my other rigs. Go figure.
