EeePC Carputer
HardOCP News
[H] News
Apparently carputers are big in Russia too, who would’ve thunk it? This guy hacked up an EeePC and stuffed it into his dash. I have no idea what he said but photos are universal and there are a bunch of pictures of the build process here.
Coolness. I wonder if he rigged to be like iDrive and tweak car parameters from the carputer.
eeePC701G (понравился 7-дюймовый экран - как раз то что надо)
I liked the 7", which turned out to be necessary
usb touchscreen
усилок JBL GT5-A604
Amp
usb звуковуха Terratec auerion 5.1
USB Sound card
usb bluetooth 2.0
usb GPS GlobalSat BU-353
usb BTC Mini Wireless Keyboard+Joystick Mouse 9116URF
usb камера использовалась встроенная в ееепс
USB camera- used the built-in one in the eeePC.
Wifi 801.2B/G встроенный в ееепс
Self-explanatory (built-in wifi in the eeePC)
usb cardreader SDHC
3 usb hub 2.0
3 радиатора для проца и мостов..
3x radiators for (something) and bridges (not 100% sure)
inverter 12v-220 100Вт Neodrive
"All in all, it took me about four months of work."
The first think that crossed my mind is that this can't be in Russia because the wheel is on the right side.
Apparently someone was thinking the same thing and asked that question in the comments, but was told that they have no laws about the wheel location.
It's like OMFG!!! can you imagine not having such law?
IIRC there is no law in the US about which side either, and I know there are none in the Bahamas about which side.
That's pretty f'n cool, but it'd be kind of a waste if all that work was just to listen to music =\
I don't see what the point of a carputer is.
Get an off the shelf GPS and an mp3/cd player for music... what else do you need?
Yes it's kind of cool to build, etc but, :p
It's a Honda Fit. Which is awesome right there. I wonder if it's a "stand alone" though - just used for hard drive space, or still uses WiFi, etc to do other things on the go.
There is rules and regulations about this, but with rules and regulations comes a lot of loopholes.
Looks Russian to me based on the graphical UI text.
This looks nice, the guy did a nice and clean job.
it seems rather useless if its not a touch screen. having to yank out a keyboard every time you want to skip a song, or change something seems rather stupid.
People import R32s, R33s, and R34s all the time as right hand drive. You have to do some loop holes to do it, but there isn't anything illegal about driving a RH drive car in the US. You can build your own without any problems, which technically is how you "import" the above mentioned cars.
I'll do the obligatory Russian-American thing and translate further, so you get some of the stuff the creator is talking about in their forum.
The discussion goes on about using the eee-PCs inherent abilities to read media like CDs and DVDs and their implementation.
The use for the radiators that mentioned was necessary because he found the regular solution made noticeable sounds and was annoying.
He points out that the use of software in combination with a 4 channel amp he added provides a much better listening experience than than "factory available".
He states that the eee-PC is also connected to the car computer, the diagnosis computer, and points out that aftermarket testers for this car normally cost $50 and above, where as he could diagnose an issue on his screen.
He also points out problems with voltage regulation from the car and the type that the eee-PC prefers and intends to replace parts to accommodate less fluctuating current.
There are several requests for a guide to reverse-engineer but he hasnt responded.
