Cousin Patty
- Jul 21, 2005
Ok I'm very seriously considering putting together my first water cooling setup. Ive had way too much spare time at work and Ive been reading alot of the threads here in the Water Cooling forum. After filtering through a ton of posts and opinions, I've come to some conclusions regarding what components are the best/pretty badass for a good setup. Im gonna break it down and you guys feel free to make comments, however the main reason I am making this post is because I have some questions about shit I am not clear on. But before I get to that, lemme see if I understand some things. Keep in mind that I am a "noob". It would appear that:
1) Most everybody here gets stuff from Danger Den
2) One of the best pumps is the DD5 12V (I know its currently out of stock)
3) Alot of people use the Black Ice Xtreme Radiators.
4) the TDX CPU waterblock is pretty badass for 754/939
5) the Maze 4 is pretty good for GPU's
6) Tygon is the best tubing
7) Worm clamps are the most reliable if you tighten the shit out of them (within reason)
Keep in mind that this is a generalization based on my research here in the forum.
Now, things I don't understand/ have questions about are:
1) Tubing sizes. Some say 3/8", some 1/2", some 7/16". I have a Lian Li pc-65. Its pretty cramped inside, even with some pretty decent wire management and sleeving. Seems like 3/8" would be good for a small case but how does that connect to the DD5 Pump? Is an adapter needed? Or is the hot water/hair dryer/ stretching method ok?
2) Is it even possible to mount any of the Black Ice Radiators Internally or Externally to a Lian Li-PC65? I DO NOT want to cut anything. I do not have access to any cutting tools whatsoever and all this watercooling shit costs enough as it is without having to buy expensive ass tools.
3) Since I dont want to cut my case and use a fillport (which I also dont understand), it would appear that I need to buy a reservoir. The clear ones at Danger Den look pretty cool. However, how do you add coolant after the initial filling? In other words, when the coolant gets low. Do you have to drain everything and break everything down and pull the reservoir out or what? Since I was planning on getting one that fits in a drive bay, its pretty not possible to fill it while its in there. I just dont get it.
4) Coolant. I want to have UV reactive coolant in Green. What is the best stuff to get that will give me non-conductivity, algea killing, peformance, and the UV. Individual product beak down would be great.
5) Will the setup below cool the shit I have more than just adequately? Id like to do some decent overclocking. Mainly on the video card. And more imortantly I want it to work well with any future components I may get. Faster vid card and CPU.
My current mock-up is:
Pump: DD-5(when it gets in), Radiator: Black Ice Extreme II, TDX CPU block, Maze 4 GPU block, Tygon tubing, either a 3 1/2" res or a 5 1/4". I dont know which fans yet.
My current system is: Processor : Socket 754 Athlon 64 Newcastle (i think is what its called) 3000+ (not overclocked)
GPU: Sapphire X800 PRO (overclocked processor from 475mhz to 559mhz)
Those are the only things I want to cool.
I know its a long post but I must understand!
All comments are much appreciated.
