Anyone in here edit their recorded lectures from class?
I'm using WavePad and I'm just beginning to explore it.
Question 1:
1) There is "noise" in the recording. Even after applying two methods of noise cancellations, "Spectacular subtraction" and "multiband noise gate -40db" I can still hear it.
I then applied "band pass filter 8,000-12,000" which seemed to get rid of the noise.
So my question is: What is the range of human voice, and the humming hissing, is that a low or high frequency? It appears to be a high frequency, how do I find out exactly at what frequency the noise happens at?
2) Does it matter in what order you apply the effects? For example:
High pass filter 400Hz
automatic gain control
spectacular subtraction
band pass
Any tips for editing lectures?
My main problem seems to be the constant noise...
Question 1:
band pass
