coolkishan
- Aug 5, 2005
ThermoChill 3/8" BSP 1/2" Barb – Nickel ( x2 ) ( For the rad is this right? )
ThermoChill PA120.3
DD12V-D5 Pump Variable Speed
D-TEK FuZion CPU Block
Danger Den Dual 5 1/4" Bay Reservoir
Tygon 3603 Tubing 1/2" ID 3/4" OD
FluidXP Extreme
Hose clips for securing tubes on barbs
What case would all of that fit in ? I was thinking of the Lian Li PCV2100 Plus but someone said that it wouldnt fit?
Is that watercooling setup ok? What have a missed out if anything ?
Thanks in advance
ThermoChill PA120.3
FluidXP Extreme
Thanks in advance
