ECS P6IWP-FE Suspend to RAM Problem HELP!!
2marshall8
I have multiple ECS P6IWP-FE rev. 2.0 motherboards and they all have this same problem. Each one has an LED1 light (according to the manual) that glows red each time power is applied to the board. The message ECS gave in the manual for this is below:
"This red indicator turns on if you system is suspended to RAM. In a suspend to RAM, the system turns off most of the power-consuming components except for the 3.3V required to refresh the memory. If LED1 is turned on, it warns you that your computer is still active and you should not carry out any work on the motherboard."
I've tried removing the battery, resetting the CMOS jumper, switching power supply's, switching RAM, switching power cables along with power strips. But on all the motherboards this same problem occurs. I'm not sure how the other three came to this problem but the main one I'm working on was found in a monitor save mode in Windows and wouldn't come out from it (like a computer coma). The individual who diagnosed it this way then proceded to shutdown the computer and it remaineded in this state ever since. The problem is that I can't boot any of these motherboards. Nothing turns on. The fans don't even turn on.
Any help would be greatly appreciated
thanks
marshall
P.S I can send the manual if you really want to help me out. let me know
