ECS Motherboards?
Depends on what board you're talking about. Most of their lower end stuff is pretty cheap. It'll run fine at stock settings, and maybe even OC a little bit, but it usually doesn't have very many OCing options like the more expensive boards.
Overall, I don't see a problem buying ECS as long as you don't expect anything more than stock settings. It'll be stable and you shouldn't have problems with it. I use 2 or 3 in computers I have lying around and they all work fine.
I've only had one mobo from ECS. and it was ok. nothing fancy, but like kirbyrj said, don't expect too much out of it.
They say ECS is a cheap brand. Is this true?
My sister bought an ECS mobo combo with a Duron processor a few years back and the mobo came with bad audio, still hasnt rma'd it.:( So yeah, im not sure but they sure are inexpensive.
ECS use to be the biggest motherboard supplier untill asus beat them a few years ago. They also make motherboards for a lot of different companies. As far as their own name boards they hold up as good as anyone elces. Most of them are not great at overclocking but for stock enviroments they are fine.
i`ve had one ecs mobo a while ago, socketA days,
it was good and cheap while it worked, it crapped out within a few months of use (no overclocking), i haven't bought another ecs mobo since and probably wont unless they have a
killer and quality overclocking mobo on their hands
I'm currently using a Socket 754 ECS board on a SiS chipset. >_> Got the bundle a few years ago. Overclocking options are very disappointing (Can raise FSB a little but with a BIOS update you can go a bit further) but more than enough for my 3200+. Onboard LAN crapped out several months ago. Other than that, it's been trucking along just fine.
I joined this board just to warn you about ECS motherboards. They are junk, and Worthless. If you want to cause yourself problems and agrivation with a computer, use ECS. I have built probably 50+ computers in my life starting with an 8088-2 chip. Had a 30 meg hard drive. Thought it would be the last computer I would ever buy. Man, what a joke. ECS forum and support is non existant. Quality is poor. It is no wonder that Frys gives them away with the purchase of a processor! Save yourself, and buy a quality board. Your welcome, Larry
i dunno, um... I've had a pretty nice ECS board. A lot of features on an entry level board for an affordable price. I even had one take my Pentium 4 3.0 to 3.5ghz which isn't huge, but it's something.
As long as you don't expect a lot of extreme clocks out of them they should work just fine for stock settings.
