ECS Motherboard Gripes
mknawabi
Is it me or are these motherboards incredibly cheap? (in regards to quality.) I remember we had an Athlon XP machine on an ECS motherboard, and the thing would randomly bsod, despite the fact that the memory was great, and the system was running on a fresh format.
Is the quality of ECS motherboards still the same? I try to stay away from them at all costs, because I dont believe their motherboards are built well.
Am I wrong? What do you guys think about ECS?
They are built the same as anyone elses boards...
Elite Group is also a huge OEM for many companies...
If you don't like them, don't buy them...
I've built about 5 machines using ECS. Out of the 5, only 1 board gave me problems. YMMV though. They are generally less expensive than competitors. To cut price, they have to cut something out of the cost of making the board.
That being said, I just built my Conroe system yesterday using an ECS board. Build went pretty well and system seems stable (have to do more testing though).
Cheers
ive probubly built 7 or 8 systems in the last year with ecs boards and all are still working fine.not o/clocking boards just plain stock speed boards.its my opinion they are as good as any other board designed to run stock speeds.ive even had good luck with pc chips boards as long as they were run as they were designed to.id buy ecs without hesitation for a stock system.
ECS, PChips, Matsonic, Amptron = HSING TECH, or commonly known as Houston Technologies. They have been around for years. :rolleyes: The only good board I had from that company was the K7S5A.
Might try reading some of our recent ECS mobo reviews as well.
As others have said ECS has been around a while and makes a lot of motherboards for OEMs. Up untill a few years ago they were the biggest suppler untill asus passed them. Right now they are #2 in the market if I remember right. For a no thrills board they work fine and hell some of them don't do so bad for light overclocking. When I use to work as a tech for a retail chain I use to specail order them in for combos. They worked fine. I built at least 100 systems using them and had great luck. I would recomend them for a normal system.
K7S5A V1.x, ran for the warranty length, board was fine until the cheap caps blew up on it killing the VRM.
see here:
http://www.rebelshavenforum.com/sisubb/ultimatebb.php?ubb=get_topic;f=1;t=000175
K7S5A V5.x "PRO", ran very well, booted at 150/150 aka 300DDR, sold it, still running.
ECS 748A (PCCHIPS M848), died when my ANTEC TP430 killed it (BAD fuhjyyu caps in the ANTEC)
Building an ECS L7S7A2 aka version older version of the 748A/M848
All boards worked well right out of the box, I've had ZERO problems getting these things working, so I have no idea why so many people struggle with them. I don't have a magic wand for building computers!!
MD
ecs is a oem company they make MB for abit and the likes. back in the day they were pretty crappy . but you could call DFI's early mb crappy and it wouldn't be a lie either.
in the past i wouldn't take a ECS if it was free. but i also wouldn't have taken a DFI or intel if it was free either.(in those days)
but times have changed . i bought a number of ECS nf4's in socket 939 and 754 and they worked fine and even overclocked some . stability wasn't a problem . no ram incompatibilitys and also there was no problems with PSU-- unlike the horrid problems i had been having with the much more expensive DFI's . the only drawbacks of the ECS's was that they would only do 250fsb overclock--even with the overclocking bios that gave 400fsb as an option--none of the settings would work above 250--lol
ECS is a very basic MB. with a low price , they don't update bios very often and they lack working bios options but can make a decent system for the $$$.
Im 0 for 2 on ECS mobos working correctly. Neither seems to work w/ ATI X700s. Lots of game crashing, BSODs, blackouts, etc. On one of them, I tried to flash the BIOS, and had my first flashing problem, killing the chip. Didn't want to waste the money to replace the BIOS chip. Hell, one of the mobos couldn't even run IE.
Personally, You couldn't pay me to use an ECS mobo, but your XP may be different.
Here is a cross reference courtesy of a guy I know on other forums...
These are socket A boards...
PS
Abit VA20 is an ECS KM400A-M2 (1.0)
AND
IIRC The Abit bios works on the ECS board or vice versa...I read that on one of the forums...
Your source of information wouldn't be bigred from OverclockersClub I assume? He always stressed that ABit was consumed by the Houston Technologies family yet I failed to see any evidence of it till now. ;)
