ECS mobo sound not working
Kevin5255
The sound on my new build will not work at all. my mobo is an ECS nforce4-A754, and the ECS site has no sound drivers, so I'm sort of stumped as to where to go from here. Anyone know a way around buying a sound card, or should i just suck it up and spend a few bucks on one?
Did you check the CD that came with your mobo?
What motherboard model is it? No, you shouldn't just suck it up, a sound card is expensive and won't really give you better sound quality anyway.
