ECS KN1SLI EXTREME Raid problems
Like the title says I am having difficulties with raid on the ECS Board. It has two controllers the SIS controller which only supports Sata 1 (don't want to use it) and the Nforce 4 Ultra which supports 4 sata II (I want to use this one). I'm trying to run 2 74gb raptors in raid 0 for performance.
What i've tried-
I set up the drives for raid in the bios but it doesn't give me any options for striping vs parrallel or whatever. So I went on with the install and when I got into windows It seems they installed for data protection in raid 1.
After this I ask around at bit-tech (not getting many responses) to hear about needing a floppy of the raid drivers and the possibility of a seperate raid bios (which I believe only applies to the sis controller) They told me to try pressing ctrl-a at startup which resulted in nothing happening which means one of two things:
1) There isn't a seperate bios for raid and I need to install drivers while installing windows
2) I'm pressing the wrong keys to get into the bios
Since i couldn't find out how to get into this seperate bios I then tried to boot the drivers into the startup. I have a few problems doing this:
1) I do not own a floppy and no floppy was included with the board so I cannot use a floppy to boot the dos files
2) I have a usb flash drive that I can set to bootable but cannot figure out how to make it be bootable. I also have another dvd drive that I could use with a bootable cd but again I get lost in figuring out how to make it bootable
3) I cannot find any raid .dos files included with the drivers cd. I've also searched the website to no avail. I have yet to try the nvidia website though but I will do that after posting.
My questions/the things I need help with:
1) What button does ecs use for getting into its seperate raid bios if there is one?
2) Can I use a flash drive to be my bootable media and how do I do so?
3) Where can i find the raid bios/drivers that I use on my bootable media for the Nforce 4 SLI Ultra chipset?
Well I just fucked things up even worse. I read the guide that nvidia posted for enabling raid and it told be to press f10 when told to do so. The only problem is that my board was loading so damn quickly I was never able to do so. To fix that I set the cpu multiplier to 4 thinking that it would slow down everything and allow me to see when to press f10. Unfortunately it would not post at this speed so I quickly grabbed the top hat flash, installed it correctly and restarted the computer. Only after did I discover that it completely erases the bios instead of restoring it to its original state......fuckers. So now I have to reflash the bios s well as figure out how to set up the fucking raid. I think the people over at nvidia should figure out a way to integrate all of the raid options into the fucking bios. Why can't we click enable raid and then choose one of the options we have available with our drives. It's just too simple I guess. More information on whether or not flashing works...
I guess the tophat flash is supposed to re-write all of the bios files so maybe i didn't put it on long enough. Trying again right now.
And the day just got terribly worse.....
I installed the tophat flash correctly the first time and tried multiple times to get it to work. I believe now that it never worked in the first place and was in face faulty. So in confusion (The manual really sucks for this motherboard if you want to understand raid or this stupid tophat flash thingy) I turned the tophat around and placed it in again. I put my finger on it to make sure it was in place and immediately burned the shit out of it due to the chip frying on me. So now I'm pretty sure my motherboard is useless and I need to buy another one... I think I'm going with DFI this round. Fuck ECS
