ECS K7S5A and reg pc3200?
2Fresh
WIll pc3200 work with this mobo? I am selling some and the guy needs to knw it it will work in it. I would assume t does, but figured I would ask here 1st.
Here's a good table for comparisons: (Scroll down a bit)
Comparisons
Also, here's a link to the specifications of the different models of your board, casuse i dont know what version yours is:
specifications
Just look at the memory section and compare it to DDR400 (PC3200)
hope that helps
Slickire /I can't teach
Yes and no...
see here for various types that work...
http://p199.ezboard.com/bk7s5amotherboardforum
we discuss this all the time at the ezboard K7S5A forum...
What it boils down to is that only certain modules work on the K7S5A, so there is not really any benefit of attaining DDR400 for a K7S5A...
Many of us can get the boards to top out at 166MHz or 333 bus speed, mine boots at 150MHz...
so here's my form letter I use...
Some helpfull hints...I'm a K7S5A owner too!
Best bang for your buck is the XP2400+ or an XP-M 2600+ to XP-M3000+
Don't bother trying to find a model 8 T-bird 2600+, you'd have better luck winning the lottery!!
Go to either of these links and get the latest Honey-X bios:
http://pub140.ezboard.com/bk7s5amotherboardforum
http://www.rhcf.com/sis-bin/ultimatebb.cgi...gi/forum/1.html?
Get rid of any PC133 or DDR2100, get 2-256Mb sticks of Crucial PC2700 Ram
You can OC this board, mine boots at 150/150 and will do 166/166, it depends what revision your board is, I ran my rev 1 board at 13.5x146.7 with an XP2200+. My Pro (rev5) has had Bartons (333 bus cpu's) running on it.
Stop by the first link, I'm veedub76 over there, Jhawk and -Milt- are also there, -Milt- can help you squeeze some decent performance out of the board..
http://milt.websiteallies.com/Beginner'...g_the_K7S5A.htm
Try to find these for out of the box upgrades:
Barton 2800+ (266) = RARE
Thorough bred B XP2600+ (266) = RARE
Barton MP2800+ (266) = Expensive
Barton XP-M 3000+ (266) = Best bang for your buck
drop by if you have any other questions...
MD
