http://www.newegg.com/Product/Product.aspx?Item=N82E16813135259&cm_re=itx-_-13-135-259-_-Product
Anyone know about this?
It is cheap.
It is cheap.
Supported CPU
CPU Socket Type LGA 1156
CPU Type Core i5 / Core i3 Clarkdale
Looks like a pretty straight forward, no frills board.
I wish there was a picture though to see CPU placement
I guess it wont be taking the p55's i7/i5 (curse you intel for your awful naming nomenclature)
your DFI T36 can use an i7 860 and better CPU placement for a larger heatsink. Also, no USB wifi support was included in your package.
The CPU placement is horrible making OCing virtually impossible.
As my soon to be released heatsink test will show, the intel standard cooler is garage. Luckily an H50 should still work with the board...but they are still putting those capacitors right at the edge meaning the top bracket part will hit it...grrrr.
Stick with the DFI in my opinion...it has issues but it is the best out there.
I don't see any real advantage of the Intel board over the ECS feature-wise, unless you need raid... and the ECS is $50 cheaper right now at the egg.
The fact that its an intel & you can count on it working consistently.. When Fry's 1st opened in vegas they had a Mobo CPU Combo just about every week with ECS boards & I Must have returned maybe 50 or 60 of them (over the course of about a year) before I stopped buying them. I Would just talk clients into spending the extra cash or I just wouldn't bother so since then I wont play with any ECS toys anymore.
Sadly, I wouldn't be surprised if you bought & returned the exact same board several times over. The Fry's back home was notorious for tossing returned items back on the shelf without regard for why the item was returned in the first place.
why cant this use an i7-860
It can.
CPU Support list Model: H55H-I
That was probably back in the early days. ECS had some QA issues BITD but started getting better around the Athlon 64 socket 939 days.
My only beef with ECS these days is their warranty policy, which is not end-user friendly.
