ECS Elitegroup ?
slamcmy
hi guys what you see in my sign is exactly what im running right now.....now my friend is selling me a 2600k / ECS Elitegroup P67H2-A3 Mobo / 8 gigs ram ballistix for under 380 dlls......my question is, ive never heard of ECS mobos so im kinda scare to pull the trigger on it......will i see a difference in performance ? im also gonna buy SSD...is basically an upgrade please lemme know what u think of this mobo and also what kind of OC can i expect with a mobo like that...ill be buying h50 or h80 to cool cpu and also ill run 32 gigs ram.....thanks in advance
I worked with ECS / Elitegroup mobo's way back over the span of the last decade and before, always were cheap little boards that were not tailored for the enthusiest but somehow strong enough to push a decent oc on. Though they never lasted long. :(
Personally I'd just get a Gigabyte or MSI and call it a day, no reason to mess around with that junk in this day and age.
ECS do some very good boards, some meh, and some cheap. Usually BIOS is not up to Asus/Gigabyte standards.
A P67 board has been around long enough you should find reviews.
A 2600K is a great processor, yes a 3770K or 4770K are better, with a couple tricks added.
You only get 2 SATA6 connections. It will easily overclock to 4400 or so, some chips, on the right board hit 5000.
8 GB are $60-70.
comments on motherboard not encouraging
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135279
