ECS A780GM-A Issue: IDE Controller Dead?
Hey everybody -
I'm in the process of building a home theatre PC, and I decided to use one of those fancy new AMD 780G chipsets since I had an old Athlon 64 3800+ laying around that would do great for an HTPC build.
Well, I ordered the ECS-A780GM-A and am having the strangest problem with it. I'll start out with the worst part: when I turn the thing on and see it POST, I get a 'Secondary Slave Drive - ATAPI Incompatible' Error. Now, while this could signal a bad cable, bad IDE device, or something similar, take note that I get this error even if nothing is plugged into the IDE port on the motherboard.
So I figure it could just be something going wonky if I don't have an IDE device installed, so I throw a hard drive in there to see how it responds. Well, I don't get the 'ATAPI Incompatible' Error this time. Instead, the BIOS is able to detect a hard drive. 'Great,' I think. This should go smoothly now. Not so much, as it stands. The POST hangs for a second, and then out of the blue I get another error: 'Secondary Master Hard Disk Error', and I get a 'Secondary Slave Drive - ATAPI Incompatible' error, even though nothing is plugged into the IDE cable except for the hard drive.
Also, when checking the BIOS setup, the Hard Drive that was detected is apparently a 0MB drive. Figure that isn't quite right, either.
I'm thinking that this board is dead and I need to RMA the hunk of junk and get myself a replacement. Should I try and exchange it for another brand of 780G or something? Doesn't seem like ECS has the best quality control on their boards. GigaByte looks like they have a good 780G board, but it would also cost me more than I feel like spending. Should I pony up and get a new board or just try a replacement A780GM-A?
Thanks for the help,
-Mech
