I just bought the Frys combo and well im taking a shot at overclocking it.
So far I was able to bump the fsb up from 133 to 150 for 2.66ghz to 3ghz.
It seems that if I go further than that it will crash.
Is there an acessible memory divider or something so I can try to go a bit higher?
Some bios options I see...
Hyper Threading: enabled (should I just disable it since the 805 doesn't have hyperthreding)
Maxcpuid value limit: disabled
Execute Disable bit: enable
CPU TM Function: TM2
........Thermal monitor mechanisms.
........TM1 Freq >= 3.6ghz FSB 800
........TM2 FReq >= 2.8ghz FSB 533
(definitely dont know what that is, so I wrote more down)
Cpu OC Function: Enabled
Frequency: 133
PCIe Clk Synchronize: Disabled
Cpu VCore Auto 1.425-1.6v
DIMM Norm->+.045
NB norm -> +0.15
DRam Freq Auto, 400, 533, 667
Is there anything I should look at?
Could it just be the ram I got thats limiting me? I have a stick of 512mb DDR2 4200 Cosair Value Select ram.. (YES I know value ram but value ram has worked well for me over the years)
Frequency: 133
DIMM Norm->+.045
NB norm -> +0.15
