PWMK2 said:OK, have to warn you guys, it's pretty horrible...
**snip**
i have an E6 venice on the way. opterons are overratedHeligrin said:Whats with all you people and your opterons
we're not doing a latency test here, bandwidth. tccd and some micron will own the voltage loving ram in the facejustin82 said:figured it would be nice to get on the list for a little while b4 all the heavy hitters start bringin the bh5 and opterons out.![]()
i'll show you something in a while that proves otherwise.. 2x1gb definitly can compete. what really needs to be done is seperate things into single channel, dual channel and NUMA capableBudwise said:how about we seperate these into a 2GB, vs Other category. Us 2GB guys cannot compete...
(cf)Eclipse said:i have an E6 venice on the way. opterons are overrated
i'll show you something in a while that proves otherwise.. 2x1gb definitly can compete. what really needs to be done is seperate things into single channel, dual channel and NUMA capable![]()
easy, just know where to look. i've got 4gb of ram sitting within 3 feet of me that can easily break 300mhz on an opteron that doesn't like going over 305Heligrin said:Where/HOW do these people get 300 mhz frequency ram modules![]()
(cf)Eclipse said:easy, just know where to look. i've got 4gb of ram sitting within 3 feet of me that can easily break 300mhz on an opteron that doesn't like going over 305![]()
I like, but when you mean look, what exaclty do you mean?(cf)Eclipse said:easy, just know where to look. i've got 4gb of ram sitting within 3 feet of me that can easily break 300mhz on an opteron that doesn't like going over 305![]()
nope, 2x512mb g.skill LE, 2x512mb crucial ballistix, and 2x1gb teamgroup xtreemMC FLMJIG said:Have a weird feeling they might be tracers...![]()
Sunin said:P.S. what had not effect to much of my surprise was changing from 3,4,4,8 to 2,3,3,5. I changed 1 parameter at a time one step down at a time and saw no significant change in bandwidth!!! Which kinda made me look at my screen crosseyed!
Stellar said:This should not surprise you. Timings are a function of latency, not bandwidth.
MC FLMJIG said:ahhh, I thought they were 1gb x 4.
What in the world is teamgroup?
(cf)Eclipse said:actually timings do effect bandwidth, just not a huge amount in sandra. a64's bandwidth is more sensitive to timings than p4's, because it changes the latency to a higher percentage.
it's mostly depenant on memory mhz though.. faster ram = higher theoretical bandwidth
lower latency = higher efficiency, thus more bandwidth is utilized properly![]()
I wouldn't use Sandra to measure bandwidth. I mean, it's purely synthetic. I had a P3, that Sandra thought ran at 10GHz for some reason, and I had sky-high bandwidth scores to go along with that. That orange bar actually went out of the window all the way accross the desktop...(cf)Eclipse said:actually timings do effect bandwidth, just not a huge amount in sandra. a64's bandwidth is more sensitive to timings than p4's, because it changes the latency to a higher percentage.
el rolio said:so what then produces higher bandwith if not timings?
i think eclipse started this as a reverse psych way of gettin us to get our systems clocked right. kinda like how the best teacher you had in school would give you outlandish but fun tasks to learn some boring bit of physics or chem or math or englsh even. that eclipse... such a tricky guy
Stellar said:I could probably break 8k if I wanted to do like the rest and temporarily bump vdimm and have it just stable enough to run Sandra. This is how my machine runs on a daily basis.
http://www.tarleton.edu/students/st_bostick/membandwidth.jpg
ah, i normally don't either, but it's a fun activity. don't spoil it for the othersiddqd said:I wouldn't use Sandra to measure bandwidth. I mean, it's purely synthetic. I had a P3, that Sandra thought ran at 10GHz for some reason, and I had sky-high bandwidth scores to go along with that. That orange bar actually went out of the window all the way accross the desktop...
