Ch!lledBudwei2er
- Apr 15, 2005
I'm currenlty using 1 x 120mm Akasa Amber front and same for rear.
Now the upper HDD cage is currently not in use so I took it out and have fitted a internal 120mm Akasa Amber via a Zalman fan bracket cooling the upper right motherboard area.
Now it seem that I will have to install the HDD cage so that I'm able to install more than my current 5 x HDD.
Im now worried that thoose HDD wont have any cool air flow over them.
So.....
I was wondering if it would be a positive thing to add two 120mm ambers to the window for extra cooling?
One in both the X areas
Top X is cooling 2-3 HDD plus some of the Frezzer 64 HSF, where as the bottom X is cooling the Northbridge and a little of thr GFX.
Mostly worried about upsetting the air flow, but I'm pretty sure that it's going to have a positive effect, more so seeing as the fact that side of the case in winter gets some very cold air
All my fans are controlled for noise, but the Ambers really aren't a noise worry.
So.....
