EC2 - spot instance How To
ChristianVirtual
[H]ard DCOTM x3
Try to quickly compile what is needed for a spot instance
1) SELF DISCIPLINE IN TERMS OF COST CONTROL ... it can get pretty quick expensive is uncontrolled !!!
2) Amazon account for AWS
3) Login into the console: http://console.aws.amazon.com/
4) Choose EC2
5) Define SSH key pair (on your own or from the console) ; cant't snapshot due to my keys shown
Suggest to use the SSH key for password less connection via ssh -i
6) Define security group (basically allow ports and IP)
I have four group ; you might need one (e.g. BOINC-style)
here I allow port 22 for SSH, 31416 for BOINC client, 3389 I forgot and 36330 for F@H (yes, I sometimes use EC2 for them too); in the source field I have my fixed IP address nnn.nnn.nnn.nnn/32 to keep you guys away from my instance
Choose a spot instance
and check the "Price History"
Mainly go with the "compute optimized" one (forget GPU, too slow and painful)
More details here: https://aws.amazon.com/ec2/instance-types/
You can see the development over the past which helps you to determine a price limit
Once decided you can request one or many instances of the same type in one shot
On the upper part of the screen you mainly define
1) Number of instances (here 1)
2) Which AMI (first go with Standard Amazon Linux Image; then once setup is done save it)
I have my CV_BOINC image (with private keys; thats why not public)
3) Choose the instant type (for the count choose in 1)
(here I used 32cores)
4) Availability zone
(opps, was lazy here; but cheapest choosen)
5) choose the security group (here BOINCstyle as defined earlier)
6) choose your key you want for SSH connection
7) set a price limit (lower right part of screen)
there is so much more ; but right now we need to focus on France-smashing
8) Launch
once launched it can take a bit time to get the instance created; you can follow the progress in the "Instance" window
Once its running and checks done you can scroll to the right and get the IP address
then a simple
ssh -i <private key file> ec2-user@<IP>
then you have a CentOS style Linux you can use the installation guide as your wish
<to be finetuned>
