When I built my PC 3 years ago I used to know all about the Nvidia cards, what the model numbers meant, etc. I certainly know that a higher number does not mean better card because there are value and performance versions in each line. So, I need help please!
I need to replace a Geforce 4 Ti4200 on an old machine (I know, I know) and want to know which of these is the best option. The card works just fine, but the fan just went out and it's only a matter of time before it fries (really hot already). This machine will not be used for heavy gaming--only watching DVDs, viewing pictures, and the standard Windows stuff. A good chunk of CPU time and RAM is already occupied by current processes (virus scan, firewall, auto-backup program, etc.).
Machine specs:
old HP custom
P4 1.4 GHz (Willamette)
640 MB RDRAM (yes, that's old school too)
Windows XP Pro SP2
Requirements for card:
**AGP slot only (no PCIe)**
Must have DVI out
From pricewatch:
Chaintech Geforce FX5700 128MB $38
http://www.futurepowerpc.com/scripts/product.asp?PRDCODE=VCCH-SA5700128&REFID=PW
PNY Geforce 6200 256MB $50
http://www.futurepowerpc.com/scripts/product.asp?PRDCODE=VCPN-G62256APB&REFID=PW
PNY Geforce 5200 256MB $56
http://www.futurepowerpc.com/scripts/product.asp?PRDCODE=VCPN-GFX522APB
others?
I want a good, reliable card that won't sap my already low system resources with Win XP, etc. Which of these three looks like the best option? I'd prefer to get the cheapest one, but will spring for a more expensive one if warranted.
Thanks!
edit: fixed last link
Machine specs:
old HP custom
Windows XP Pro SP2
Must have DVI out
From pricewatch:
others?
Thanks!
