easy speeds
Rhino
i just got my barton 2500 on my nf7-s to 2.17ghz, 217 by 10, i have 2 sticks of 256mb corsair xms pc3500. Im currenty at DEFAULT volts. I have slk 800 and a smartfan 2 on that sombitch. im currenty at 38c, should i worry about raisin the vcore, to try and go further? also, should i be worried about the temps, even though i got it at auto shutdown if temps reach 60c
someone help, i had my fsb at 217 and my ram in sycn 6/6 and then i went to change timings to 11-2-2-2, and when i restarted my pc wouldnt boot, fans work, hd works, everything works, even lights on mobo? i cleared the cmos and restarted nothign, what should i do???
When you say you cleared the cmos, you can't be sure right because it still won't boot, so maybe it didn't clear afterall.
Have you tried all three of the recommended methods? The three are listed here, though I'd imagine you've already checked Abit's site...
http://www.abit-usa.com/faq/mb/2002073001.php
Good luck. Sorry I couldn't help more. I'm sure you'll get more qualified responses tomorrow morning.
ok its back and workin again, ihad to take the battery out, and clear cmos, and now it dont work at 217 anymore, so i take it i have to raise the cpu volt
